creaking for a while now i get a clunk!
right had a creaking from the front passenger side for a while. which i put down to the upper link arm....
now ive done the usual searching the forum ect
i now have a clunk from the same side :headvswal
now there seems to be a few culprits which ones are most likely
tension bushes?
ball joint?
swap bar bushes?
spring?
shock?
also the linking bar from the strut to the swap bar i can move the assembly by hand but can't get it to cluck is it normal for a bit of play there??
this is doing my head in and i have an mot looming!! :nelson:
thanks guys n gals
gaz
normally tension rod bushes especially at low speeds,speed ramps etc,if its when you hit a big divet or pothole then its most probably a shock
yes its when i hit a bump ect turning right ect
shock seems ok tho??
Nope, it is a dead cat that hid under the arch!
:nono: its cos i have to work on your car i don't get enough time to work on my own :rofl: :rofl: :headvswal
could it be anything to do with the stabalizer bar?
not likely,more likely to be a shock absorber
My tension rod bushes were knocking. I changed them for poly bushes and no probs since!
[sIGPIC][/sIGPIC]
tension bushes?
ball joint?
swap bar bushes?
spring?
shock?
thanks guys n gals
gaz
Gaz, after the conversation I had with you the other night this is *not* very reassuring. Hope you get it sorted mate. Let us know what the problem is once you've found it. Great cars... but there's always something.
yes there 15years old+ there will always be something LOL
sure its not your lower control arm mate - Ive had a few of them do this
You cant tell until you undo the 2 tension bar bolts - they seem to crack under these.
  • 1 year later...
bump. this is still happening but i have replaced the upper link arms and lower tension rods with powertrix fully adjustable ones. creaking and clunking still. when i replaced the tension rods the lower arms were mint so i had ruled out the cracked seat of the lower arm.
what about a pheasant?????? Dont they cause a clunking noise???? :tongue:
also have a quick look at the boltholes throught the lower arms where the tension rods join, one of mine was cracked causing movement and hence a nasty clunk, just a thought.
  • 1 year later...
this is still happening on my z. and i still havent got to the cause of the problem. sound high up in the wheel arch and i cannot replicate it when car is stopped. it also doesnt do it all the time eg bumpy roads but a pot hole or sharp lump will cause it occasionally??!?!?
bloody odd as everything seems tight and no leaks etc!
upper arm bushes bud funny H shaped thing....just had mine replaced all noises and movement gone...put up with it for almost 9 months :D
upper arm bushes bud....just had mine replaced all noises and movement gone :D
upper arms are powertrix and so are the lower tension rods. i replaced with these to try and elimiate the problem. thanks tho
ah i see..... i got the following info off smithys place under the adj upper arm section... might help
Note: Must be used with solid/bearing type front tension rods to prevent caster play, otherwise bearings may experience excessive wear.
yep replaced them at same time. i have powertrix pillowball adjustable tension rods and powertrix bearing upper link arms. and i still get the clicking/clunking.
are there any problems generally with the upper suspension mount for the shock/spring? the rubber bit at the top? this is what im thinking it could be and is there an aftermarket replacement for it?
its possible when buying/replacing shocks you dont fit a new rubber easy to overlook that bit so maybe prudent to get some new ones cant be too expensive being a common part...they maybe the original ones on there and smashed flat after years of use
