standard air filter removal
is it just me or is the a real pain in the arse to do?
i can take the T piece off but the plastic air filter just dont come off, the bolts attaching it to the car are to hard to get to.
what do i do?
should i just break it off, because its starting to piss me off now!!!
:smash: :smash:
The back left is easy the back right is abit akward but you can get it okay.Front pair ,all you need to do is slacken them abit with a flat spanner,as the ring they go through has a split in it then give it abit of a pull and away she comes."THEN BIN IT" LOL
i remember getting really ****ed off with mine and drilling out loads of rivets... then binning the thing!!
what do you think shall i just drill the f***ers out, did that work then?
yep - I've seen a few people say the same... only downside is you can't whack it back in after an accident if you've not declared your mods :x:
wait till the weather's warm - it's much easier - or warm the rubber intake pipe with a hairdryer.
Good luck
Jack
i used a big set of bolt cutters to cut the whole airboxes out ... worked a treat - and it was quite satifying getting my own back on the Zed for having such a stupidly hard engine bay to work in!!!
