Uk Spec Hid Conversion
Hi Guys
I am planning on converting from standard headlights to HIDS. I already have the kit, just reading threads, before fitting. I have read about needing to modify jap spec wiring so that when you use main beam the dipped beam do not switch off. This makes the bulbs last longer. It says that UK spec wiring is different.
I have also read that you have to modify the wiring on UK spec as the dipped will come on dimly (dim-dip cct has to be removed).
Does anyone know what i have to do on UK spec to achieve the above? If so could you E-mail me the info PLEASE?
Hope to hear from you soon.
Regards
Kev
No posts to show
