Sequence of events
Now, being a novice in styling etc. I need to ask, to achieve a customized Zed, where do you begin ? Do you buy the wheels first and then work round them or do you buy the bodykit first and then the wheels ?
Also how much does it cost to buy a full body kit and get it fitted ? Are there specific places or can any bodyshop accomodate ?
Finally, to change the colour of the Zed to a completely different one, is this considerably much higher in costs than keeping the same stock colour ?
Where is the best place to get a bodykit and wheels ?
If I want a wide arch body kit, then obviously I need wider wheels ? However, if I buy the wheels first then am I not restricted to the body kit that will accomodate the wheels ? What I am trying to ask is where do you begin, wheels first or bodykit first ? Also who does good dewals og kits and wheels ?
Cheers !
Cheers !
http://www.300zxstyling.co.uk or http://www.zcentre.co.uk
Wide arch is a little different in that, yes the wheels can affect it. Depends though. Many fit wheel spacers when fitting wide arch, which means stock width and offset wheels will accomodate wide arches.
If you have stock wheels I would upgrade them first. It makes a dramatic affect to looks as well as alloweing wider rubber and lower tyre walls, for improved handling and braking.
You have to decide what the finished artical is going to be!
A wide arch kit needs either spacers or custom wheels.
So what look do you want? wide arch project is £6000 plus,
with out custom wheels, you can add around £3000 for
some -31 offset rears @18x10 with 9x18 + 25 off set fronts
So deside what you want and then price it up.
Allan
My apologies Syed for hijacking your thread, but I have spotted a Gruntpa dig here. You want to make sure your gearbox is Ok first tho.
