my zx when starting from cold revs high and low
Cannot work this one out? its a twin turbo just had O2 sensor replaced, the car is still when starting from cold reving up to 1500 then down, sometimes staling, is this just beacuse the engine is cold? if the air is on or the heater it dosen't stall. Does anyone now what is going on? oil pressure is good everthing seems to be running fine. Please can anyone help me with this.
cheers rob
Have a look on Macieks' website (Z Viking)
He has a tech write up on this.
www.z-car.net
Steve
Thanks Steve!
Rob,
This sounds like a problem with the idle air.
Did you clean the Throttle bodies recently?
If not, then that's the first step.
If you read the write ups, you'll that there's a ton of things involved but
cleaning the throttle bodies is a good first step.
Good luck!
Maciej
Yeah sounds like the IAA assembly is screwing about check the tech page posted and go from there.
SteveE and Maciej how you boyz been doing not heard from you both for ages drop us a line and let is know whats new.
Z ya
Nico91TT
Dont be a Punk ...
In stores this Friday ... Hurry only limited stock remains ;) ...
Nico, you've got mail...
Maciej
thanks for everyones help, thats made it a little clearer about the problem
cheers
thanks for everyones help, will get that checked out
