I will be taking my engine out in a few weeks to replace the turbos .Been told why it is out to do these jobs as well :- det sensor harness,Egr value bypass and new pcv valves .Can you think of any more jobs ,money will be tight .
Best place to get hold of the det sensor harness and pvc valves
cambelt or 60k service if its due
rear main seal
if manual no better time to do clutch aswell
pcvs and hoses
egr removal inc welding up manifold and egr feeds optional not nec,but if you remove plenum in future,it saves a load of hassle :)
water bypass to turbos
det sensor,but plenum removal is IDEALY required
check heater matrix hoses/replace
clean injector plug harness and injectors connections
check oil return pipes from turbos replace if nes
check turbo to downpipe gaskets replace if nes
check engine mounts
if removing plenum,replace intake gasket
02 sensors although you can do it fine with engine in,its so much easier whilst its out
all of the top of my head,maybe more,i took an engine out today :rolleyes: still cant think lol
as for pcvs and det sensor ask ryan ztech as he offers best price on pcvs and most new parts,failing that mjp
Cheers Greg the list just kepts getting bigger and bigger :(
has anybody got any links or pictures for these jobs
got to remember you dont need to replace half of what i have mentioned,its either precautonary or not needed if parts are ok
dont remove gearbox with engine,the amount of links and advice to remove the gearbox,makes me laugh gearbox stays where it is,so dont follow gearbox section/engine removal on TT.net
