autobox noise?
when i put it in drive or any gear theres is a slight knocking noise from box,when moving you cant hear it only when stopped.gearbox feels fine ,but just that i have never heard it before as my aircon bearings was making aload of noise.
is this something to worry about or is it a normal ..like i said its a slight knocking noise .seems like its going with the speed of engine if you see what i mean.
thanks
I aint no expert but! any knocking is not good. I dont wish to piss on your fireworks but I would have it checked out. if it gets faster with the engine then it sounds like something may have broken could be the torque converter. As I said no expert tho'
Whatever it is I hope it dont give you too much grief mate.
When my autobox went there was a knocking noise with a metallic grating at the same time whenever I pulled away or came to a stop. Sounded like it came from the passenger footwell. After about a week it became more and more reluctant to go into overdrive and the oil went a brown colour and smelt burnt so I knew then for definate what the problem was, you sure its not suspension noise as the car goes into drive and you get the slight lurch forward?
its not suspension noise.you put it in any gear drive/1st etc and sit there with foot on brake.
its not very load but soon as you move you cant hear it and autobox feels good ,only when stopped and car is ideling you can hear it .
sorry but its hard to discribe
Got to say it does not sound promising from that, why not give Ryan a ring and have a chat about it, hes the man that sorted mine out when it went and its like driving a new car now hes sorted it, nice positive gear changes.
how much did it all cost mate
well worth changing the auto transmission fluid m8
if the filter gets blocked it will also make a noise
as you say hard to know just from a description
but for the amount it costs and the £££££££££s it can save you
worth doing m8
worth doing m8
Could be worth a try first, drop the pan at the bottom of the box, clean the filter, if you havent got an aftermarket cooler fitted then do so and then refit with new oil, see what happens. Worst you are going to do is waste 20 quid and a couple of hours of a weekend. Oh and catch flu (these things always happen at winter time)
yes i will try this 1st .thanks for the help.i will call ryan and ask him aswell.
If you are about on Monday I can take a listen to it and let you know what I think, could even hook up my conzult and see what that says.
im in france from sunday till thursday. im free fri 10th,sat 11th,sun 12th.
if you are about
cheers
Should be able to take a look Sunday morning, would have to be about 10am though.
no props do you live in ipswich or on outskirts ,its about a hours drive i think from me.
I live right in Ipswich mate, I will drop round yours and take a look as I will be in Peterborough Saturday night and travelling home Sunday morning hence its needs to be about 10ish and you are kind of on route for me.
update on this
checked level this morning and when cold it was in the hot marker and when warmed up nothing on dipstick :headvswal , so after a few tops up i.e 3/4 of a litre its in the hot mark when at running temp and when in netural.
the noise is still there and you cant hear it when cold.
and you cant hear it from the outside even if under car.
