UK Spec Rear S/Belt Pic Needed
Anybody got a picture of the rear uk spec seatbelt and how it mounts? got to fit one to my car and looking at the belt im confused how it all mounts up.
Any good? its fairly easy once you get the trim / seats out and self explanitary.
I have posted pics before of the car as I did it which shows it all stripped out and the mounting points but they are not on my pc anymore, a search might bring them up.
Cheers mate, ill have a search again, but that give me a good idea on the top mounting anyway :)
This is all from memory so may not be 100%, the top mounting you will see when you remove that piece of trim, make some measurements and drill through the trim in hopefully the right place. Measure and cut the piece of trim you see in the second picture, again hopefully in the right place, the mounting for that again was already there, i bolted it in, offered up the trim then cut it and found a piece of trim in the workshop to finish it off. The last 2 mountings are where the lap belt already is and a straight swap. HTH Richard.
luckily the bottom section of kit came with the UK spec trim so it has the gap already for the belt top come through, its just the top mount i need to drill. just need to work out which way round the reel goes in lol.
When you get that trim out it must be self explanitary because I did it without any headscratching just bolted it straight in. If any of you guys take your kids out in your imported Zed this is a must do mod, those lap belts are a waste of time.
is that the reel in the top middle of th picture?
Wow, I'd swear that's my screw driver in that pic. Suspect it's Ajay's car when I was installing the traction control ....
mind you i cant even get to be able to pull the seat belt out without it locking LOL maybe it has to be in installed or something.
It does, once they are fitted they should pull out fine.
marcuss just look at my car sunday
or just come up and do boost leak at same time
Cheers for the offer mate, ill probally pop up whne i get stuck half way thu lol. Im not sure on the boost leak now due to a post on it, i think it may just be weather conditions causing different boost levels on differen days. Blumin turbo cars confuse me lol
least the wife cant say now that i jsut spend all my money on the car without thining of the family lol
suppose i better start retrimming the tweed whe i got the panel off as i have tons of vinyl lying around.
anyone know if i can fit these to my 90' n/a 2+2???
and if so how much do they cost???
cheers
murf
cheers
murf
Speak to Ricerocket or AndyZ and they will give you a price for these, my car is a 1990 NA 2+2 and I have them fitted :)
