Brake issue..
Hi,
My car seems to pull to the left when I brake. There is a bit of a crease in the brake line on the passenger side. Would this be the problem? The other side seems to be fine.
Bart
I brought a new hardware pack for both the front calipers a little while ago and had them stripped with new pads and disks?
doubt it would cause a problem, its more likely to be a sticky calliper.
Fraser
Yes, seals etc. He's supposed to have anyway..
so the calipers have been rebuilt?
does the hardware pack mean piston seals like?
I dont like the sound of a crease in flexi brake hose might be worth changing these maybe for braided ones.As i had a peugeot 205 gti with the same problem and it was traced to a internaly colapsed flexi brake hose the hole in the centre was so small that the fluild couldnt get to the piston . :cool:
The thing is, it's the metal pipe that has the crease. I'm thinking that maybe the fluid is being forced through when I put on the brakes, but not flowing back so easily when I let go. So they are touching the disk. So when I press again after that, more pressure is on that side? Just a thought. what do you think?
