Recelogic Digital Adjuster Problem
Just fitted my digital adjuster to the existing TC unit and had a quick mess about with it but it doesn't seem to save any of the changes I make if I turn the ignition off.
I presume it should do or it's pretty useless....
Any ideas?
Any ideas?
does it need/have a permenant feed to it??
Nah, that'd be silly, all changes should be saved in NVR on the main box - this device is a just a controller through the serial port (I think).
It says to connect it to a switched 12v on the ignition which i've done.
The adjuster seems to read the settings from the TC box OK but there isn't an option to save the settings unless I've missed something obvious.
I presume it's just meant to save what you changed automatically.
Wondering if the TC box has thrown a wobbly after being out of use for so long and the engine out.
Quite possible some muppet hasn't connected it back up right.... will investigate tonight.
