auto dump valves
will they work on an auto 300 i got a pair on but i've still got the standard ones on i've been told they are under the headlamp panel is this right and are they easy to remove and block off.
any help is much appreciated cheers Chris.
they will only work when yout take your foot off the accelerator and they arn to hard to fit. blocking off the olld recirc pipe can be a bugger and getting the old ones out is also a bit of a bugger
yeah tell me about it someone told me you have to take the front end of the car off that cant be right surely can anyone give me instructions on how to remove them
getting the bumper off is pretty simple, especially if its been off before and not all the screws were used to put it back on.
I would recommend removing, nose panel, air filter and the fan and moving the oil cooler out of the way as best you can (if you have one)
Still tight and awkward but you can just about get to everything.
They come off relatively easy once you locate the bolts on the recircs and undo the jubilee clips.
I meant to take photo's when I did mine but didn't, sorry.
