Which Boost Controller
At some point my car has a boost controller in and i have two plugs on the main loom 1 either side of the engine by the suspension mounts i cannot find anywhere they plug in, (I belive they are actuator plugs) anyway the only thing i can think of now is to put a boost controller back in as im worried about these plugs so which boost controller would you go for???
cheers Craig
what colour are your plugs are they grey or black??, do you have any pics??
they are grey plugs, i will get some pics up this evening
cheers craig
cheers craig
They're the boost solenoid connectors I presume.
Would be disconnected for the boost controller to work but unless you've had bigger turbo's fitted or something then the other connectors should still be there.
If you look where the wastegate control solenoids are you should see the solenoid mounted on a bracket above the turbo with a couple of thin black pipes and a connector (the ones you found?).
The other connectors that join them should be hanging down or maybe strapped up out of the way somewhere but can't be far away.
Without these connected you won't get safety boost.
