Auto gauge gages
why would these gauges not work on your jdm? do you think it needs japanese style gauges?
Don't think they won't work mate but not had the zed that long and i know the jap and uk models use different readings bar ,psi,etc.I've started modding and want a reliable guage to see if everything is o.k.Don't want to blow up my baby.
ok. they will work on either jdm or uk. i got mine from gaugeplace on shegay! he a good lad.
Cheers for the reply.Although my profile says Leeds i'm actually living in cas at the moment ,Black 92 tt,So not that far from you.You may of seen me facing the wrong way on roundabouts in the area,brand new tyres and all.
not seen u yet! give me bell if u get stuck with owt! there not much i aint dun to mine now!
Won't be long before i drop you a line.What colours yours ?Seen a yellow and a white one around Cas.Off on mi hols in a few days but when i get back will post pictures of mine.Thanks again.
mines black manual! that yellow 1 is 1 of my old 1s.
aint seen the white 1 yet. mine off road till april so i can get new stuff fitted.
The only difference between psi and bar is the dial. Off the top of my head you get 14.5 psi for 1 bar. But if you had bar guages and wanted to read in psi, all you would have to do is simply replace the guage (assuming its mechanical), the inside of the guage does all the readings the rest of the hoses etc, just allow you to connect into the required hoses.
