I have 2 noises which I would like advice on how to cure (I am fed up turning the sterio up!).
The first is from one side of the Instrument Console, and I guess may be there from re-assembling following the Speedo change (kph to mph). It sounds like plastic on plastic and is there with every bump in the road. Is there a recommended compound to use to isolate the two surfaces?
The second is a noise that I remember from every Estate car I have sat in? I guess this would be the Tailgate hinges, and is a high pitch smooth metal on metal. It is there every time the car flexes. Any advice on what can be done?
There may be other common noises that I may "introduce" as I go around modifying/upgrading the car, so any tips on what to use, etc. would be welcomed. (e.g. when fitting new speakers into the doors).
Thanks, Geoff
