Water pressure
And more to the point why would you want to measure it ?
Generally, it will be fairly low anyway, except when the temperature is up around (and over) boiling point.
If you have standard rad cap then water pressure should be (0.78-0.98 bar) (11-14 psi)
Looking at some gauges and they are dual read outs.
Pointless now cause its reads to higher pressure than the water goes too.
If I did fit it, wouldnt have wanted a needle not moving!!
