In thinking of changing me z32 tt auto(import) auto box to a manual, ive sourced a manual box, how much trouble is the job and what other things do i need?
Im presuming manual pedal box,maybe differnent prop?ecu??
jezz a lot to do then is it worth it?
hi,converted my dads car last year.youll need a flywheel and bolts.auto bolts are to short as manual flywheel is thicker.new bolts are expensive,around £70.
use existing brake pedal just chop sides off and fit smaller pedal rubber.clutch pedal is a pig to fit.you need to break blanking plate off bulkhead.auto prop is the wrong length so youll need a manual one.your best bet is to find a complete car being broken.
z tech will fit it for £1500 inc the following
brand new rps sport clutch inc release bearing,spigot, etc
gearbox&oil
new rear crank seal
master cyl
slave cyl
manual balance bar and hoses
clutch pedal&booster
brake pedal
propshaft
gearknob,selector&gator
vacuem tanks to inlet manifold
relevant lines to master cyl
relevant heatshields for slave and lines
that seems a good deal better than trawling for bits many thanks
