99 spec lights
ARRGGHHHHH
How do you change the bulb in these fookers.
I can remove the side indicators ok - 2 screws.
its the little ones at the front that contain fogs and side lights.Turning the screw at the front of the light does "F" all.
Are they fixed in - do the bulbs come out from the rear through the indicator hole.
you unbolt them through the indicator hole. have a good look with a torch, you'll see them. there are 3 i think per lamp.
fookers
Cheers bud!!!
so 3 bolts - prob 10mm?
then the light unit comes out throught the front - then I presume you can get to the bulbs :)
fookers
Cheers bud!!!
cant remember the spanner size but it isnt a difficult job, just 1 of them is fiddly to get to. I did both side on mine in about 10-15 mins
And the screw is a height adjuster, so dont forget to re-adjust them when you put them back in.
