injector connectors
RIGHT TESTING THE WATER FOR REPLACEMENT INJECTOR CONNECTORS AS I THINK MINE ARE SHOT. WILL TRY AND CLEAN THEM THIS WEEKEND .
soz about the caps as my k board is playing up.
where can i get and how much are replacement injector connectors.
thanks
gaz
you can buy the connectors with a small section's of loom to repair your harness. from a good electrical supply shop . etc about £5 each
or go to the breakers with a pair of side cutters and yank a pile off. then solder them on. just make sure u get ones with the notch in the correct side. ul get them for thruppence.
thats what i did, dont even think i got charged in fact
I bet you carn't get the correct Nissan injector connectors and if you use the wrong ones you will have a crap signal (ie wrong impeedance, week voltage or a signal affected by damp or heat) and will have poor injector flows. Which could fook your engine.
thanks
gaz
I have a set that i bought from courtesey and never used because I replaced the engine loom. You can have em for £30. Give me a pm with ya details.
Bought mine from Mike at MJP. They come in packs of 4 so had to buy 2 packs £40 delivered (i think). Phoned him on Friday and they were through my letter box the following morning.
Mark
I read a while ago (can't remeber who is was) that they chopped the connectors and soldered the wires directly to the injector connector.
I've already done this with my ECU temp sender and am thinking of doing it with the injectors too, and whatever else is fooked !
ok with temp sender, but with injectors it WILL cause problems.
mine came from a brand new renault laguna, the wires are a bit thinner, but i soldered them on with only about an inch of thinner wire, so cant see that affecting the injectors much
