hi
about 7 weeks ago i changed my ptu for another series 1 because i thought it was causing running probs, such as lumpy idle and missfire. the one i put in had a constant missfire and one day it just cut out on the drive, and never restarted
so i bought a new ptu from the states which never showed up so i got one off vijay with the wiring, put it on and is still wont start i have put more petrol in it checked all the fuses but it just wont start, there is a smell of petrol from the exhaust?
i am at a total loss :cry:
anyone got any ideas where to start, or what to do?
all help greatly appreciated.
Richard
take your plugs out and clean then up and warm them up.
make sure all the ptu connections are working etc all the usual ;)
i have had same problem for past few weeks list of things done
new S2 ptu
new ecu temp senser & harness
new fuel temp senser
cas checked
all connections cleaned etc
checked AFm
changed fuel reg & dampener
new plugs
fuel pump
next thing is try another fuel pump control unit and different ecu. still wont start when it does it will idle perfectly then after approx 10/15 mins start hesitating and cut out so im really :confused: at present
