Better Brakes
I need better brake discs as the stock ones are no longer up to the job!
anyone recommend a good set??
They are 330mm instead of the 280mm that comes standard on a Z.
Nice thanks for that. I take it the rears can be replaced with skyline discs also?
Thats the way i went.
I rang loads of breakers and found front and rear brembo's off a skyline, huge improvement IMO. £500 front / £250 rear (i think) was i while ago, and bolt straight on.
Jap breaker in/near norwich.
R33 or R34 ? or do they both fit? Im guessing they are going to be much better than EBC upgraded discs for the zed?
They both fit straight on, though the 34's require a very minor mod of drilling the caliper holes out slightly bigger. FYI the GTR's are 324mmx30mm.
Just be careful that sometimes the discs can be a bit naff when buying these kits second hand, usually a good bit of age and often heavy use, calipers are good though ;)
cheers
smithy
AP 6 pot brakes!! the only way to go :D
vbgarage.php?do=getimage&id=2511
Standard discs Vs AP Discs
vbgarage.php?do=getimage&id=2689
you cant put skyline discs on without changing the callipers can you?
yeh you can, i think smithy sells the bracket ;)
so what pads would you use? 300zx or skyline
Depends which calipers you have.
smithy does excellent portefield pads for 300zx and skyline calipers
Cheers bud..
Am running a 10% of ALL ranges of the porterfields at the mo as well ;)
cheers
smithy
