injector wiring harness
how easy is one of these to fit as this morning i seemed to loose a cylinder and when i wiggled the injector connector on no 3 cylinder the misfire went away. its ok for the moment but im thinking of changing the harness.
anybody ever done one and could give me a hand if i need to replace :bow:
do what i done, cut the complete crappy plugs off and solder the cables to the small size crimps and they fit a treat?
the harness people use on zeds is intended for a maxima.which is a four cylinder.means you have to buy 2 of them.if you have a bosch injection agent near you they can supply a plug and terminals which will do the job
and they dont cost much.
Speak to Takemetothepub mate, I think he has done this.
Cut em off and splice in new ones mate. Fiddly git of a job but not too bad to do.
saw some on phnw for £45 so looking likely to do. how far back do you have to cut into the loom as im worried that im going to fook it right up!!
:headvswal
:headvswal
As far back as you can/want. Unless you take the plenum off you cant go that far back anyway.
Its really not that bad, there is not a lot to f*ck up. :smash:
