Newbie help
I'm at a los here...
How do you remove the antenna base ???
I can't get my antenna all the way down. Not even by force. And in order to replace the antenna I need to get the antenna base of. but how. The screw on the antenna base is in the way.
Theres a cover plate you need to remove, two screws behind it, ariel will then fall out.
