head lights and side lights
they have suddenly stopped working, the little lights in the front bumper work (mine is uk) and the rear lights work
is there a fuse for these ive come across the ones in the engine bay and they are ok
seems strange that both the side lights and headlights to go off
any ideas :bow:
Cant remember for sure but check the drivers side footwell.
there is a 10 amp fuse top row for the side lights not sure if it will affect headlights though
mate your side lights are not the problem as they are the ones in the bumper, and connected to the rear lights / dash board lights.
Headlight fuses might be the place to start... not sure where it is though? DOes your main beam work?
none of the lights in the main lights (the ones on the bottom of the bonnet) work, only the ones in the front bumper, the rear and interior lights work
will try fuse tomorrow
cheers lads
Headlights are fused seperately, as it is UK try checking out the dim dip relay and headlight relays in the Black box under the bonnet on the passenger side, the fuses are in here too.
One other consideration though is a faulty light switch, does the main beam work if you pull the indicator stalk back like when flashing the main beam at some one? if it does then I would check out the switch.
Jeff TT
Jeff TT
yup it works when i pull back on the switch is this an easy repair, or hard
cheers bud
Looks like you have a faulty master switch then, mail me your address and will send you a spare one to try out.
Jeff TT
Jeff TT
cheers bud but cadpaul has a one for me, is there any difference in uk and jap :bow:
