Headlight Q
Guys,
Ive had some probs with the electrics lately and i had to pull some fuses out to stop the horn going off etc etc.
Anyway, i had to remove one of the headlight fuses as it that also got affected. However when i did this i notice that if i turn my lights on now the small round ones come on as well as the main beam ones on normal driving. Now i noticed that the main beam (square) lights were in fact dipped.
Now i didnt know they could operate in a dipped mode, i thought they were for main beam only....am i right in thinking that the small round ones are driving lights and the Square ones next to them (in the same unit) are for main beam only??
Or should all 4 be on?
Hope this makes sense?
Dan,.
Can only tell you how my 94 uk spec operates.
side lights = small round.
low beam = small round only brighter.
High beam = squares + small rounds.
Rgds
Rob
ah right...yeah that sounds the same mate ;)
Shame as could have done with some more light! Need to look at a HID upgrade at some point i think.
Cheers.
I had similar problems, and what I'd done, in checking fuses in the drivers footwell, I'd put one back in the wrong place. As a result the headlights were always on full beam. I think it was the top row, third fuse holder along. I'd put it one row down. Suggest you try putting a fuse in all of the spare fuse holders.
Good luck
Jack
Thnx Jack, ive left it with an auto electrician now as its all past me!
We thought we had found the dodgy wiring and i had that re-done and it was fine until i washed it and then that triggered it all off again, must have a dodgy earth somewhere i think :(
