No Go! PLEASE HELP ME ! ! !!!
Driving my Z hard up a duel carrageway against an R33GTS when i heard a thump from somewhere when i went from 4th to 5th. I lost all drive and had to pull over. Engine seems ok but clutch pedal stuck to the floor. I pulled pedal back up and when in gear with clutch up i 've got no drive, just bad vibration in all gears.
Does anyone have any ideas please???? :bow: :bow: :bow:
Pressure plate fooked
I say that becos you have no drive in the normal state so probably not release bearing
New Clutch.............. probably
So do you think its a new clutch to fix problem, will this stop clutch pedal sticking to the floor??????
So what will i need then guys???? Is it time to break open the piggy bank??
You need to install a new clutch. Also it would be wise to check out the gearbox as you say you heared a bang. Clutches don't go bang, gearboxes do. Good scenario new clutch only; bad scenario new clutch and new gearbox.
Sorry to be bearer of bad news.
ok mate. thanks for your help.
