Should I remove air-con condensor?
I've got my rad out at the moment whilst doing the front water pipes and I have noticed that the condensor for the air conditioning must have a huge affect on the radiators efficiency as it sits in front of the radiator, restricting air flow considerably.
My air con has been junked already (no compressor etc), so is there any reason I should leave the condensor in place? I'm sure if I take it out the car will run better/cooler, this can't be a bad thing considering how hot the engine runs. :confused: :confused:
Anyone out there removed theirs?
Thanks,
Gareth
Gareth, I took mine off my 200sx, my air con was knackered too. Pump, various hoses & condenser weighed 19kg!!
If there is gas still in your system you will have to be careful though (mine had all leaked away)
M
if you've already ditched the compressor i cant see any reason for keping the condenser???
Sounds like the consensus is to bin it. I'll take it out tonight, cheers guys.
