Zed serivce in plymouth?? oils & brakes & idle problem
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi guys, my zed is coming up for it's next service, is there anyone around the plymouth area who could do it, that i can trust!, while it's in for the service i need new pads all round too, this is the first service since i owned it should i do anything else apart from engine oil & filter?.
Are these jobs i could do myself? im quiet handy with a spanner :smw:
What i need to know is:
what oil to use?
what filters do i need?
what brake pads to use?..
Also i have an idle problem, when coming upto a junction or a stop my revs will drop to 0-100 and then pop back upto 1000 rpm then the engine hunts half a dozen times before it settles down, sometimes engine will stall but only if im slowing from high speed!.
I have removed the aiv valves and prvr system & cleaned the iacv according to the guides on this forum :bow:, but i had this problem before, my brother thinks i have a vacume leak on the near side down by the turbo somewhere! could he be right, i think i can hear it but it may be the vacume noise from the balance bar!!! (could i be wrong?)....
When this hunting problem occurs if i swith on my air con (the auto button) it is still the same, BUT if i put my front screen blowers on the idle settles fine at around 800rpm, then if i switch the front screen blower off it will settle at around 700-750rpm perfect until the next time it happens which is often. i have got into the habit of swith=ching my screen blower on when coming upto all junctions or stops now.
If i drive the car upto a junction or stop going down in the gears slowly coming to a stop the car will act normal 95% of the time. i cant work out whats going on please help, it's strting to drive me NUTS.. cheers
