hicas
After some help, have a silver 300zx twin turbo manual,jap 1990, after driving about 6 or 7 miles the red hicas light comes on ?? fluid level ok no leaks!! if car stops and sits for 2-3min start her up and no light on !! any ideas ?????
Mine does exactly the same. I was told that its low PAS level or poor electrical connection. Have checked level seems ok cant be arsed to check electrics yet as its to cold outside
Try the above it might be asimple fix ?
do you have an aftermarket steering wheel may have the wrong boss on it also if you still have the original steering wheel it may not be aligned properly HTH
Yes have have a momo wheel and boss on ! speedo once stuck at zero !! happened once in 6 months,, any ideas??? dont know about the boss but i think its is the correct one fits nice and snug, how would the boss annoy the hicas??
Yes fluid level fine , all wiring been checked by my mate who is nissan mechanic , hes looking into the hicas at work ,says there is not much info on the 300 at present !!
IIRC there is a sensor on the steering coloum that senses where the steering wheel is if its not centered properly it turns off the Hicas as a safety precaution HTH
should use search as its your friend...lots of info on the subject..as zxally as said you need the correct boss to make sure the hicas set up runs fine...
Mark
just put a touch more oil in dude...mine does it when the oil gets just very fractionally below the top...
my hicas light has been on for ages until today. there appeared to be plenty fluid in the tank so i dismissed this as the problem, then this morning i topped it up and hey presto! problem solved
no mate just normal power steering fluid i use castol TQ Dextron 111 HTH any make will do as long as its dextron 3
