Well as i got my car just last weekend i decided to get it dyno'd and make sure the fuelling was ok i.e. not running lean..
fuelling runs a bit rich at part-throttle and on full-throttle it runs a tad rich over 4k...so i'm happy enough with that for just now.
made 334bhp and 379ft/lb of torque..
nismo 555 injectors, JWT ecu and boost jets (as far as i gather) and running at 14psi..
those the sort of figures to expect?
cheers.
Is that at the wheels I presume? thats about the same as mine (yours has more torque) and I'm running a little under that boost so yeah it sounds good. Maybe you should think about an electronic boost controllers? as you are running high power and boost jets aren't very reliable. Nice figures by the way, it must pull harder than Silvia Saint. Dave
that's at the fly i believe so..
hmmm do you really need 555's at 14 psi? or have you got big plans?
just got the car last week and it has them fitted and the fuelling is pretty ok, just running a tad rich so i've no plans to change them or really get more power... just get it mapped a bit better.
out of interest, what's a safe limit to run the standard injectors to? psi wise on standard turbos, roughly.
about 1 bar on stock injectors. i run 16psi
