Wheel spacers
Hi all,
I got j spec stock rims all round and heard you can get spacers for the rear to get the wheels to fill the arches a little better, anyone know where i can get these or any alternatives ?
CheerZ
Paul
Wow thats a good idea it would give the car a fatter look. Have you tried Halfrauds?
you can pick up universal ones in all sizes.
try ripspeed, or motor shops.. they all sell them and usually for a set of 4 will cost aprox 30£ if that....
i have a set of 5mm spacers you can have, taking them off my fronts at the weekend to replace them with spacers with built in bolts
Mike
When i fitted my Brembos i got 3mm spacers from Halfrauds but im sure they can do bigger ones.
Mike
Nice one, I'll have 'em mate.
Does it look better with the 5mm extra ?
yeh it did but tbh i have 8.5 inch fronts anyway and only had to space them to clear my AP 6 pot brakes ;) but i'm not happy with how much thread the nuts go on so got some new ones but yours will be fine.
PM me your address and i will get them out once there off
Mike
anyone put spacers on the front with standard rims to bulk them out a bit? I've been trying to get a pair of UK rears to put on the front. This might be an easier way.
Or else I should just get a set of 18"s LOL
You can use a slip on spacer 3mm 5mm or 6mm with the standard studs you can by bigger slip on spacers i have some 10mm ones but the are not safe you have to use with longer studs .Then you get to 15mm bolt on these are hard to get hold of genraly jdm makes only.Bolt on spacers come in two sorts hub centric and non hub centric .Hub centric are made to fit the nissan 66.1mm centre bore .non hub centric are still 5x114.3 pcd but a bigger centre bore to allow for other makes of cars.Bolt ons come in 15mm\20mm/25mm\and bigger for wide arch kits etc.
