clutch throwout bearings help!
Hi all,
When I pull away my car makes a noise when I lift my foot of the clutch, only notice the noise in 1st and 2nd. Could it be the clutch trowout bearings making a noise?
Regards,
Matt
Hi all,
Regards,
Matt
it could well be the release bearing as you say,more than likely due for a new clutch aswell whilst your at it ;)
could also be gearbox layshaft but my moneys on the above,normally a worn layshaft noise dissapears when gearbox gets warm
just a note if you mean your getting this noise whilst driving through 1st and second,sounds like road noise,then it will be a worn rubber cover which may have come loose or split under the gearshift remove centre section and check gators,replace damaged ones,v common
Its like a metallic noise when I pull away an disappears after a second or so or when above a certern amout of revs. The noise happens between 1.5 rpm - 3000 rpm.
doesent sound like release bearing,check the gators first ;)
cool, will do mate
