strange gurgling noise
hi to all
wonder if anybodys had this before,i have a strange gurgling sound coming from the car but it sound as though its down behind drivers wheel or the drivers footwell the car seems to be running fine and it only appears to make the noise when its ticking over about 1000-1200rpm.The car is running cool on the temprature guage and the oil pressure is good
so any ideas :tongue:
prob got some water in them, nothing to worry about, if you have done a de cat , they can be removed
Its the AIV's They become full of water. Do a search for AIV removal and you will find intructions on draining and/or removing.
thats what i thought but wasnt to sure.im hopefully getting the pipes changed soon so i will prob remove them then
cheers guys
if you look behind the wing u will see a n shaped plastic unit that sits behind the indicator on each side of the car, i think u can just put a small hole in the bottom to drain the water out
Found this, hope it helps...
What's the 'gurgling' sound from the front fenders?
As for the AIV (air injection valves) 'gurgling', they are in the front fender wells behind the plastic shielding at the rear of the front tires. Very few 90-92 ZXs have escaped a failure of these. Symptoms include the 'gurgling' sound at idle that stops just off idle and returns on decel back to idle. Also the car will fail the idle portion of most smog inspections, since the ECU adds 7% more fuel when they operate so the extra air they pump to the catalytic converter has some fuel to burn to keep the cat up to temp. If the AIVs are not sucking air into the exhaust the fuel just passes through making things worse then ever. The fix is to try to clean and align the reeds in the AIVs, replace reeds, or replace the AIVs as an assembly.
THE Jim Wolf of JWT (from his only known forum post!)
This information was contributed to the IZCC mailing list from Eric Rahkola:
Here's the steps to follow to fix the gurgling sounds from inside the front fenders. The Air Induction Valve (AIV) and its air cleaner are located behind the rear plastic fender linings in each fender. The air cleaner housing can retain condensation which is the cause of the sounds. In addition to replacing the air cleaner element, you will most likely need to replace the AIV valve assembly. It's very easy to do and takes less then an hour per side. Prices run about $100 for the valve from Courtesy Nissan. [ Note: Read Jim Klubens' section below on rebuilding the valves instead of replacing them, Ed. ] The AIV function, as described in the manual, is to send secondary air to the exhaust manifold using a vacuum created by exhaust pulsation in the exhaust manifold. When the exhaust pressure is below atmospheric pressure, secondary air is sent to the exhaust manifold. When the exhaust pressure is above atmospheric pressure, the reed valves prevent secondary air form being sent back to the sub-air cleaner. I've heard that de-acceleration is supposed to keep the assembly clear of water.
Note: I'll be making a TECH page out of this one day,
I did snap a picture of the valve assembly inside the fender when I was in there for a different reason... Admin.
Here's the replacement steps:
1. Jack up the car and remove the wheel. Follow all normal safety procedures - jack stand, blocks, etc.
2. Locate the removable section of the fender liner. It's located directly behind the tire tread and measures roughly 18" high x 12" wide. It's embossed with some 1" high part numbers in reverse.
3. Remove 3, 10mm bolts. Remove the reusable plastic fastener by pushing its center pin about 1/8" until you hear it click. Use a flat screwdriver to pry it out. When you reuse it later, remove the pin, insert the fastener, then push the pin back in.
4. Remove the fender liner.
5. Loosen the clamp and slide off the hose going to the aluminum-bodied AIV valve. Do the same for the intake hose going into the black-plastic air cleaner housing.
6. Remove 3, 10mm bolts holding the black-painted bracket assembly to the car. Remove the 10mm bolt holding
the top of the air cleaner to the car.
7. Move the assembly forward to disconnect the vacuum hose going to the top of the AIV valve.
8. Remove the assembly from the car.
9. Remove the rest of the bolts holding the AIV valve and air cleaner housing to the bracket.
10. Remove the 4 screws to open the air cleaner. Note the tab on the air cleaner and notch on the housing to properly orient the new air cleaner element. To prevent water from accumulating in the future, drill a small hold to act as a drain. Lay the intake half of the air cleaner down to look into the intake hose fitting. I drilled a 7/64th hole in the corner, 45 degrees and about a 1/2" down and to the right of the intake fitting. When viewed from the inside of the air cleaner housing, this is the lowest point for water to accumulate.
11. After fitting the new AIV valve and air cleaner to the bracket, reinstall, in reverse order of the
teps above.
Eric Rahkola
The following information is for the rebuild of the AIV unit contributed by Jim Klubens (Indy Z Car Club):
With the AIV unit out, follow the procedures for rebuild.
For a diagram of the AIV assembly, refer to the DOCS section and goto 2-N-06. The Nissan part number from the Reed Valve is 14845-30P00, available from Courtesy Nissan for ~$12 ea.
1. Remove the 4 screw that hold the two halves of the AIV unit together. (Make a mental note of how the unit comes apart, specifically remember the two hoses ends. If I am not mistaken, the two ends where the hoses go on go in the opposite directions.)
2. Remove the rubber assembly that holds the two reed valves in place.
3. Remove the reed valves from the rubber asembly and replace with new reed valves. Note: It will take 2 reed valves per AIV unit. My personal experience with the rebuild was I only had to do the drivers side. After careful examination, the passengers side did not need to be rebuilt.
4. To put back together follow the directions in reverse.
A rebuild of the AIV assembly is very easy and should not take more than 1 hour per side. I would also advise to clean the AIV assembly during rebuild.
Jim Klubens
