Help - Refilling the cooling system
I will be putting a new OEM radiator in the Zed next week.
I have previously had some trouble with refilling the cooling system, in particular I think I had some air trapped in the system.
I understand it is best to have the car on an angle when filling but can anyone tell me what is the best way to fill it so that I don't trap any air in the system?
Thanks, Mike...
while filling, leave the engine running with the heater set on max temp and max blow. This will help getting rid of the air.
Vijay
Vijay
Thanks Vijay, Should the car be on an angle?
When you say an angle, make sure it is nose up, i.e.radiator higher than the heater matrix. There is a bleed point on the left side of the radiator. (should be - mines a Jap import)
well I've never bother raising it and had no problems.
Vjiay
water, who needs that, air coolin does the job :tongue:
