taking out the bulbs.
Ok, i cant seem to get to the front lights to take the bulbs out, does anyone know an easy way to do it as i cant get my hands in :(
Also im still not possitive which bulbs to get, legrath said it was H3 bulbs but when i went to halfords they were saying its something else and with me not being able to get the bulbs out to check i was stuck
Someone help me please :D
Membership No 0780
INSURANCE GOOFA
OK first you need small hands! theres a thread Ill find for you on bulbs just hang on..
It can be done mate, you just need
double jointed hands! Theres a spring
clip to remove (the hard bit) then the bulbs
should be easy to get out.
You dont say whether its a jap or uk spec
as the bulbs are different.
you need standard h3 bulbs ignore halfords they tried to sell me h4 and h1 bulbs for the z, untill i told them i had taken the bulb out and it was def h3
OK, so its just any H3 bulb from halfords then???
Not that getting them helps when i cant even get them out. :headvswal
Membership No 0780
INSURANCE GOOFA
Yes, normal H3 bulbs will fit your UK car. If you don't fancy paying Halfraud prices for uprated H3 bulbs then give me a shout - I can now supply an array of bulbs - check out the bulb thread in the DTA section of the Traders Forum for prices.
To get to your dipped beam bulbs:
1. twist the plastic cover ring counter clockwise to undo it (should only be half a twist)
2. pull back the rubber cover, this will expose the actual light bulb housing
3. there is a spring clip which you'll need to undo by pushing on the small metal lever and then pulling it to the side
4. you'll now be able to pull out the bulb
5. disconnect the spade connector from the wiringloom connector and insert the spade connector from your new H3 bulb
6. reassemble the light in reverse order
It can be a fiddly job, especially on the passenger side of the car but definitely possible - you just need patience!
Hope this helps!
Danny
Hope this helps!
Danny
Typically enough its the passenger one thats gone ;o(
Thanks for that mate, i got as far as the spring clip with great difficulty then i was stuck as my hands are too fat :headvswal
Membership No 0780
INSURANCE GOOFA
is it the 501 bulbs or something for £8???
If so how long will it take to get them as i need to do asap
Membership No 0780
INSURANCE GOOFA
Hi Lee,
I know we've just spoken on the phone and I'm sorting out the bulbs but for everyone elses reference:
UK Spec cars:
Dip beam (circular lens): H3
Main beam (rectangular lens): H1
J-Spec cars:
Dip beam: H3C
Main beam: H1
Fog light: H3
My prices are:
H1/H3 55W (standard spec): £11/pair
H1/H3 100W (uprated): £14/pair
plus £1.50 postage
Conversion on H3 bulbs to fit J-Spec cars: £5/pair
Foglight bulb will require minor modification to the spade connector
Speak soon mate.
Dan
I would definatly recommend the bulbs danny does, had some uk spec 100W dipped bulbs and can now drive my zed at night and see where im going!! Fiddly as but if you take your time and scratch your hand, knuckles and anything else you try to f*(k you should get the bulbs in and out...
hopefully it'll not be too bad, ill get it eventually :D
Membership No 0780
INSURANCE GOOFA
yer or die trying lol!!!! make sure you have plasters at the ready and something to hit (in place of your zed) when it all gets too much!!!
Thanks for the vote of confidence lol :headvswal
Membership No 0780
INSURANCE GOOFA
yes, sorry shouldnt credit everyone else with my in-abilities.... best of luck sure it will be a roaring success
Paul - I bought some of these bulbs last year and are a waste of time. They both blew within 2 weeks. The glass was bubbled to hell. It looked like they had melted. This seller 'Dellogs' sells from Japan and Australia....total crap.
