code 22
guys just did a ecu check got code 22 but its not listed plz help because zed wont start cheerz.
You sure you didnt miscount lol
LED codes for MODE II:
11: crank angle sensor circuit
12*: air flow meter circuit
13*: engine coolant temp. sensor circuit
14*: vehicle speed sensor circuit
21: ignition signal circuit
26*: boost pressure sensor
31*: ECU
32*: EGR function
33*: exhaust gas sensor circuit (left)
34: detonation sensor circuit
35*: exhaust gas temp. sensor circuit
42: fuel temp. sensor circuit
43*: throttle position sensor circuit
45*: injector leak
51*: injector circuit
53*: exhaust gas sensor circuit (right)
54: signal circuit from A/T control to ECU
55: NO malfunctions in the above
Maybe you need a proper cable to check the codes and carry out a full diagnostic check on your vehicle.
apprently code 22 is fuel pump,but when i turn ignition can hear pump prime and it doesn't keep on buzzing deffo code 22, 2 short flashs 2 long= 22 have checked every possible thing and all seems fine, would the ecu give a false code ??
