Can anyone tell me what the difference is between brake master cylinders for a twin turbo and non turbo is? they have different part nos. thanks.
The twin turbo has a booster that sits between the clutch pedal and the master cylinder, so the actuating rods in and out come with the booster, the non turbo master cylinder has an actuating rod built in ( unlike the twin turbo one ) so it goes through the bulkhead and fixes directly to the clutch pedal.
Hope that helps
Jeff TT
:o Arghhh Bugger just read the post again, you said BRAKE not CLUTCH cylinder :o
Oh well if anyone wanted to know the difference on clutch cylinders there you have it.
Jeff TT
not sure it could be different size's of bore on the cylinder i know there are 2 different size fluid resivoirs as well on is 52mm one is 80mm but not sure if thats between turbo and non turbo hth kev
