2 things
1 when i started my car this morning the hicas lights came on then swithced off after 15 mins. im sure the fluid level is ok
2 when i turn the key just before i turn the ignition on the stock turbo gauge goes just to th increment after o is this normal? then wheni switch on my car it goes to just below the 7 and boost to just below plus 7.
could this be anything todo with code 34 cus that what i get.
1) normally fluid level - double check and also check for leaks,
2) thats normal except for the boost level , Will sit at 0psi until engine started , Then sit-7 until driven then boosts up between 9 upwards depending on what boost your running. 7 psi however indicated , Safety boost. Get a conzult check done bud and yes code 34 ( det sensor) will put you in safety boost.
-7 0 +7 is in millimeters of mecury on a j spec
-14 0 +14 is in PSI on a uk and is the same just different measurements
