Anyone heard of this???!!!
Hi,
It's a long shot but Im looking for an End Stage Driver/Transistor Pack which I believe is located at the left hand bank/front of the engine bay, as mine has had it. As well as this I am after the multi-plugs either side of this part which are part of the wiring loom. I need about 6-8inches of the wire and plugs.
If anyone has any of these parts spare or if anyone is breaking a 300 I would really appreciate if you could let me know.
Cheers guys,
Paul.
PTU (Power Transistor Unit). Series 1 PTU's are a weak point, go for a series 2 PTU if you can, it also comes with harness adaptor.
I might be able to help out on a used series 2 PTU if that helps.
Vijay
Vijay
may also be interested as my S1 is playing up can you plz let me know cost thanx
Thanks for the responses guys, is this part going to come with the multi-plugs on the wiring loom as its essential that I get this part as Nissan don't seem to sell it! Is this the harness adaptor or something different - excuse my ignorance, just need to clarify as I have no idea about this! :confused:
Vijay, how much would you be looking for?
Many thanks.
£100 plus a fiver shipping. It comes with the adapter plugs and bracket :)
Vijay
Hi Vijay,
That sounds good, however....are the adapter plugs that u can supply part of the PTU or part of the actual wiring loom from the car itself? The reason I need to clarify this is cos I really need the plugs from the actual wiring loom that belong to the car as mine are no good. As well as the actual PTU!
Hope this makes sense mate!
Paul.
Hi Paul,
The series 2 PTU uses a different connector. The kit normally has the Smaller PTU with adapter plugs. What I can get you is the smaller PTU with the adapter plugs that have been cut, so you could easily connect them to your old PTU cables. I can work out what wire goes to what if you want it :)
Vijay
I need to borrow a ptu to clarify mine is fooked.....anyone in wales soon lol
Vijay,
Thanks for your help mate, i will have it off you, as it does sound like what i need.
Is a cheque ok?
If you email me your address on: Bertie@pauljbrowner.demon.co.uk then i can send a cheque up.
Regards,
Paul
