hicas light
my hicas light is on continuously, checked the fluid level and its fine, also when i turn the steering wheel the power steering pump moans when under load, are the 2 connected
what car did you buy :confused: jeez all your posts have been asking for help
id recomend booking your car in for a checkover with a specialist,do you have an aftermarket steering wheel fitted,if so then the hicas hub may not off been lined up 100% when the wheel has been refitted,if the pumps moaning then that sounds like my misses and may be on her way out :D
but seriously id get the car looked over TBH
next question! where do i take it? is it worth buying another pump, there is one on ebay now.
errr thats up to you bud.. but you do know this is a car forum dont you? not uphillgardeners.com
LOL @ scoops
errr thats up to you bud.. but you do know this is a car forum dont you? not uphill@scoops-gardens.com
no need for comments like that you bought a shitlicker gt-4 :rofl:
have a look in the traders section graham
z tech
zen garage
south west zeds
cheers greg, most helpful. can i drive it to the garage with the bottom end knocking or should it be trailered?
to be on the safe side a trailer would be a safer option a small knock can get worse and damage more bearings or at worse crank rods etc
i work at z tech,but depending where you are in the country we do offer a pickup service,but if your with the AA or RAC then you can get it done for free if you say your broke down somewhere
greg
