Intermittent slipping clutch
as it says above really its a real pain in the arse it does then another day its fine any ideas also noticed you only have to push clutch pedal a bit and it slips
Leaking clutch booster/master cylinder
happend to me few years ago had to
replace both as its a sod of a job the
money for the master cylinder is peanuts
compaired to the hassel of doing it again!
Got all parts from courtesy nissan in the
states, about £380 iirc
Link:- http://www.courtesyparts.com
oh shIIIT all i wanna do is sell the fecking thing should have stuck with my 4*4 cavvie turbo so adjusting the pedal/bleeing out the system wont have much affect then??
worth a go dont want to spend anymore on it just get shot of it !!!
you could try adjusting the pedal. That sometimes helps.
had the same problem with mines,at first i also thought it was leaking master cylinder or needing bled then when i was accelarating hard in 3rd it constantly slipped,turns out the clutch was on its way out and after fitting an RPS unit from Smithy,problem solved.
