Intermittent Power Steering
:headvswal My power steering works in the wet . Its intermittent on damp days foggy etc . & only for a short time after start up when its dry. i think it may be an earth problem, already changed the speed sensor didn't make the slightest difference any ideas?
Hi jim, believe you bought the car from my dad. hows it going. just bought one myself.
if an import check the speedo conversion as this may cause intermitant problems with steering,1st thing to do is make sure the belt tension is adequate,check fluid levels,simple things first
