Indicator problems
Iv got a 1992 300zx twin turbo lwb, the other morning i went to start my car, no problem there. I got to the end of my road, indicated to go left and the hazards appeared on the display, so tryed indicating right? same again. i checked the relay and thats clicking away fine,(could it be faulty?) checked the fuses in the kick well, there ok. If anyone has any ideas on what to check next then please help, can't drive my car until the problem is rectified and my local car electrics store want 48 pound plus vat per hour!!! and think they could solve the problem after having it in after 2? Extortionate
so if anyone can help then please do or call me on 07723 051573 cheers
Sounds like the 4 way hazard switch has not returned to its fully off position, this is usually because the fixings are causing the switch to bind on the switch pod, try flicking the switch on off a couple of times and then try the indicators,should work then, seen this kind of problem many times.
Hope that helps
Jeff TT
Tryed that one, still persists. nightmare. anything else you think it could be?
problem solved, faulty old alarm cancelling each side out making them blink together.
