New Rads
My 300zx TT auto has sprung a leak in the main rad :headvswal . I dont want to fix it.
Am looking for a good replacement that will drop str8 in, what do you think is best rad to fit. Bearing in mind the car is being modded so will be running a tad hotter.
Also should I install a new oil cooler 4 auto box & reg engine oil.
Should I also remove the ancillary rad too?
Marc
  • Replies 32
  • Views 1.7k
I know u all like to kick your toys out the pram now n again lads ;) :x:
BUT how bout some advice to the rest of my original questions :confused:
OTHERWISE......
not only will I spit my dummy out....I will tip my pram over and spill my toys everywhere :rofl: :x:
Thanks for the advice lads, its always good to hear several points of view.
I have only heard good stuff about Koyo recently....so far I am erring towards that brand unless convinced otherwise.
I just want to make sure my hard earned wedge is well spent on my lovely zed :bow:
So.... what else would u guys advise on the other rads etc.
OK..... all together now....dummies back in :x:
that slipped out, sorry....its the chistmas spirit....all 5 pints of it. :D
:rofl: good post!
sorry cant tell ya too much bud, but have just bought a koyo off chris, looking forward to getting it fitted. never seen a howe properly so cant comment between the 2.
what do you mean by ancillary rad?
can only think of the aircon rad which is right infront of the normal rad, and the oil cooler ickle one in front of that?
iv not got a prob with mine as its a uk spec, but i believe there is a oil cooler upgrade for jap spec and its on zcentre website - sorry to all other traders that can do his, but you sem to busy arguing to help out!!! :x:
good luck with it bud!
Hi M8
Yes it must be the air con rad I think. Not sure aircon needed rad tho, does it not work from compressors like normal AC?.
Just PM'd chris about some bits as well.
I like to do a good job so while the pipes are off I mite change a few bits like the under drive pulley and add a few stainless pipes etc. Im interested in what I dont need to keep on the car or what I can improve by way of oil cooling etc, maybe even upgraded intercoolers at some point.
Cheers m8
Marc PM'd you back :)
Got it, cheers chris.
Will work out all the bitz I need n get back to you.
  • 4 weeks later...
Marc
I have just done this mod last week. Put in a koyo with seperate oil cooler Will post you some pics.......put on a hard pie kit as well. Hope it stops the car overheating this year.....
Get a arc rad mate .jap made v expensive but good.
or a good condition UK one - its got 30% more cooling in it than the import one apparently.
