Its a bit of a longshot i know but i cant find any thing on the net.But does anyone know how the halfshaft on a Jeep Cherokee is held in place?
The bloody thing wont budge and now its snapped the slide hammer.Anyone work on these things before.
Thanks in advance
Steve. :headvswal
Think you have to remove the diff cover and then the wee bendy "S" shape retaining clip.
Could be a million miles out tho !!
Should know a man that knows, will make a few enquiries and get back to you, hopefully !!
Alan........
Alan........
Cheers Allan i think thats the next step.All i need now is a new puller LOL
Okeydokey then;
1. jack up and remove the diff cover.
2. spin the diff using the wheels very slowly until you see a small 8mm bolt.
3. Undo the bolt and carefully remove it, taking care not to drop anything inside. It is more of a locking pin than a bolt.
4. With this removed, it lets you push the halfshaft in towards the diff and you can then access the halfshaft locking clip.
This will either be a "C" clip or an "S" clip depending on whether LSD or not.
Again take care nothing falls out. You dont want planetery rings bouncing over the garage floor !! ;)
5. Would be a good idea to either photo, or make a note as to aid re-assembly at this stage.
If it is the bearing that is noisy and it hasnt been used too long, you should be ok with a new bearing. Oversize bearings are available if the half shaft is slightly worn, but if it has been run for a while the halfshaft might be worn to excess and would need to be replaced.
USAutomotive are good for parts: 01234 273155
Hope this helps mate and if its a load of rot, blame my mate, not me ! ;)
Alan...........
Okeydokey then;
Alan...........
Cheers Alan great description thats the way it came off.
And ill try USAtomotive becouse these buggers want huge amonts for a new halfshaft.
Thanks again
Steve.
Thanks again
Steve.
Woo Hoo ! Result !!! :D
Alan..
