Digi Adjuster Where?
Im wondering where to put my Racelogic Digital Adjuster and cant find anywhere suitable.Does anyone have pics of where theyve mounted theirs?
Steve. :confused:
Steve. :confused:
under the stereo lower compartment,did you get a block of foam type material to set it in
Hi Gregg no nothing like that,and the problem is is i have my boost controler and turbo timer there.
could see if you can mount it left of the steering wheel,where the little iluminations light up
i fitted my blitz boost controller there looked spot on
Personally, I would mount mine inside my centre arm rest. I guess it all depends on often you expect to be making adjustments to it.
some people like blingage david and have it on show :D
ah..ok...I was thinking of the old unit....not the new digi one. nevermind.
Yeh the only problem is,is that when you turn he ignition off its always in the wet setting.Also it would be a little dificult to operate the launch facility from there.
