Another Hicas Question
Hi Everybody....
My hicas arm is loose when I touch it......Would it just be the hicas arm or would anything else cause the arm to be loose?
Regards,
Matt
Anyone
Hi Everybody....
Regards,
Matt
Hi Matt
What do you mean by "Loose" the HICAS arm will move up and down cause it's on ball joints at both ends, if you lift the wheel off the ground and feel a kinda click when pushing it from side to side the rod or end could be worn.. There could be lift in the rack but it was the arms mine needed about £55 each if I rem..
Craig
there is usualy a bit of play in the arm at the jointed end,but if play is excessive then replacement is needed,they come in two parts the ball jointed end! and the tie rod itself which connects to the hicas itself
You can feel the hicas move even with the wheels on the ground, I think I need a new arm.
It has play in both ends, think it maybe the ball jointed end.
Hi Greg
Sorry ta be a bit off thread but do you have any rear bumper fixings kicking about? Cant get from Nissan till after Xmas was hoping to get my car rebuilt and back on the road well before then..
Craig
Hi Greg
Craig
we have a breaker in at the mo craig,so give ryan a bell 0796816640
sure he can sort you out bud,IIRC the rear bumper is still on so should be able to help,failing that ricerocket in the trader section
Thanks Greg
I'll give Ryan a shout in the morning is it an import?? Tried 3 uk motors but there all rotten. I've tried Dave(Rice) he's not got any..
Thanks again
Craig
