replacing digital clock
hi is it easy to do ? will i have to remove radio or anything eles to look out for thanks
Easy mate.
Just remove the centre console and it's screwed to the back of it.
Radio remains in its cage.
I believe you have to remove the screws under the strip that flicks off below the air vents above the stereo first and then remove the console. I can't remember if anything else has to come off.
4 screws - two under little plastic covers in the top corners of the air vents, and two under the long strip as described by yampie
then the clock can be removed by 2 screws from behind the fascia
and then you can replace it with a nice turbo timer or boost controller!!! ;)
thanks done it not to bad a job thanks for the help
