Fitted New Brakes Today
Wet and cold but well worth it :D
vbgarage.php?do=getimage&id=2503
Mike
  • Replies 37
  • Views 885
Beeeeeeeee...........LLLiiiiinggggggg!
Nice one buddy!
wasnt quite a bolt on kit but made it fit :)
spot on mate :cool:
how do they perform??
really well, have'nt had a chance to really try them but big improvement, just goes to show any Skyline aftermarket brake kit fits the zed with a little modification ;)
Nice one Mike! :bow:
This is gonna be a beast! I'll be following your progress. :D
Cool enhancement. :bow:
What modification did you have to do, and how did you do it, I am considering an upgrade on my Brakes, if you recommend this enhancement, can you let me have the details? eg supplier, type of system, cost, any fitting advice you have gained.
cheers
Pete
cheers
Pete
yep any bigger brakes is a good mod ;) especially over the cak zed brakes.
To make these fit we had to remove the splash shield which takes a few minutes, theres a little bit on tom of the hub which needs cutting off, only about 1 cm and all it does is have a bolt which holds a bracket which is not needed anymore anyway and the only other thing we needed to do is drill out the original holes as this kit was from a R34 Skyline which have 14mm holes so the braket was 14mm and the 300, R32, R33 have 12mm holes
So just means you cna looke at people selling not just 300zx brakes but skyline upgrade brakes as well :)
Mike
mike they are excellent brakes, what size roto's 343mm?
yeh 343mm :)
Yep very nice. I know what is going on my Christmas list for Mrs Ball Now....
Can I ask how much ££££ ???
they wernt cheap but you have to pay good money for decent stuff but under a grand ;) not much but under lol
yeh 343mm :)
small stuff mate ;) still a great set up though
356mm and 6 pots :D
cheers
smithy
Mike
Just looked at that pic again and the studs dont look like they are long enough?
i am going to get some longer studs but the nuts are misleading as they go into the wheels pretty car and are quite long so there well on ;)
Hmmm look like they dont come to the end of the nut :eek:
Have to agree with macca here bud :(
There should be at least 1 1/2 to 3 turns of thread exiting the nut
You are one brave MOFO :eek:
Get them new studs fitted asap ;)
so an inch of thread is not enough?? i had less on my other wheels and alloys on my old zed??
If you defo have 1" thread going through those nuts then its not so bad but those nutsmust be 1 1/2" long then if their still not pertruding.
If this is the case then you dont need longer studs you ned better nuts :rofl:
Pardon the pun Kirbz :D
