Manual Gearbox??
I have today picked up a N/A gearbox to replace my TT box, now the bellhousing has to be swoped over to accomadate the larger tt flywheel.
Also the N/A speed sensor has to be swoped over as the signal pulse
of a N/A sensor is different to allow for the different ratios of the diff. Today I took the N/A sensor out of the N/A box only to find that the diameter of the pinnion gear is not the same as the TT version, so working on logic I will have to use a TT sensor but with a N/A pinnion gear.
But if the diameter of the pinnion gear is different so must the drive gear
in the box, is this going to give a faulse reading on the speddo head
Food for thought
Allan
Food for thought
Allan
Dose any body have a N/A gearbox on a TT???
What speed sensor pinnion gear did you use??
I think Karl 300 had a NA box on a TT,He had a lot of clutch problems. Why did you go for an NA box?
Hi Mac
This is Karls box but i will change the bellhousing ovetr to fil the TT
I was told by the Gures on here that the N/A and TT box are the same
except for the bellhousing and speed sensor!!
It now turns out that the pinnion gear on the sensor is a different size :headvswal so I need to know which combonation to use.
I think it is tt sensor with n/a pinnion gear
Cheeers for asking
Allan
