Profec B
Just had my Profec fitted but the boost seems to drop off. There are a few settings that I need to set but have no idea what they should be for best perfformance. They are:
Gain
Set
Start Boost
Lo \Hi
Warning
Limiter
Peak
Can anyone explain in plain English what these are and approx what they should be set to?
Thanks Guys
I know dude, but there is so much to sift through and I can't find anything to explain in plain English what the settings mean...
Ok, here are the settings from my Profec B spec 2, to achieve 9psi in LO and 14psi in HI, on stock turbos:-
LO:- SET=16%, GAIN=18%, SETGAIN=48, WARNING=110 with a drop of 20%
HI:- SET=33%, GAIN=21%, SETGAIN=85, WARNING=155 with a drop of 20%
The boost signal is tee'd in from the right hand side of the plenum balance tube.
Also I have a dual friction clutch which seems to be able to handle it.
pinched it off another thread
Gain
Set
Start Boost
Lo \Hi
Warning
Limiter
Peak
Thanks Guys
SET: is used to set the desired boost pressure. Raise the % to increase the boost and lower % to decrease. 100% will boost the turbochargers/waistgate limit. 0% for stock
GAIN: Adjusts the boost consistancy(sensitivity)
START BOOST: Adjusts the boost response. (when the wastegate opens)
WARNING: Set this to the limit you dont want to go over.
LIMITER: Set this to the amount of boost you want to drop if you do go over the warning setting.
LO/HI: That is the two settings you get. You can do one lot of settings on LOW for just having a little play around, say around town. Then the HI setting for all out bol#ox on the motorway :D
Hope that helps a little bud ;)
[sIGPIC][/sIGPIC]
Just been testing these settings and my set gain will only go to 35%...why wont it go higher?
mmmmmmmmmm. will have a look at mine tomorrow bud and try to see whats going on. Who fitted it? and did you disconnect the two origonal plugs on the engine?
[sIGPIC][/sIGPIC]
It was fitted by Scott at Redline so will be done right and yep, the plugs were disconnected...
